I need some help with a technical problem. I have a CDX5122 and a Beocenter 4000, with twin tape decks radio and tuner, which were purchased in the U.K in 1983 and are now in Los Angeles. Although the CDX appears to work normally it does not generate sound through the 4000. However, if I disconnect the CDX from the 4000 and then connect my IPod, I get normal sound through the 4000. If I then reconnect the CDX, I also get normal sound but this only lasts for the duration of one CD. Since the 4000 was never sold in the US, I have been unable to get any help locally. Any suggestions as to the cause of the problem and possible solutions?
