Latest post 03-04-2009 11:34 AM by glug. 4 replies.
Page 1 of 1 (5 items)
  • 03-03-2009 4:33 PM
    • glug
    • Not Ranked
    • Joined on 06-19-2008
    • Posts 27
    Beocom 2 'No contact with base' problem
    I have recently replaced a faulty transformer that was failing to charge the handset.
    The handset now charges and the menu functions are working but the 'Information' screen is constantly on and when I press OK the display says 'No contact with base'.
    Can you tell me how to move on from this problem?
    Many thanksConfused
    Beovision 5 HD, Beo5, Avant x2, BL9, BL8000 x2, Beosound 1, BL2, Beosound 9000, Beocom2, Beogram 3000 , A8.
  • 03-04-2009 3:05 AM In reply to
    Re: Beocom 2 'No contact with base' problem
    Maybe you should register it to base again?
    _____________
    Happy owner of: BV10, 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11
    1:st prize winner Beoworld January Price Draw.
  • 03-04-2009 4:44 AM In reply to
    • glug
    • Not Ranked
    • Posts 27
    Is that a simple procedure or should a dealer take care of it?
    thanks
  • 03-04-2009 6:48 AM In reply to
    I think you should take it back to have the dealer to fix it. I assume you have the combined charging and base station. I recall I had similar problems with my first Beocom 2.
    If you have the separate base station, you press a small button on the base to put it into registartion mode. Then you go into the menu on the Beocom 2 and ask it to register to base.
    /C
    _____________
  • 03-04-2009 11:34 AM In reply to
    • glug
    • Not Ranked
    • Posts 27
    Thanks for the replies. it is a combined base and charger without a button.
    If there are any more suggestions for registering the base to the handset without going back to the shop I would be glad to hear them.
    Many thanks
    glug
