Latest post 02-16-2009 1:13 PM by bsantini. 2 replies.
Page 1 of 1 (3 items)
  • 02-15-2009 9:45 PM
    • mjmedlo
    • Top 150 Contributor
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    beovision 9 help
    I got my bs3 back from the software upgrade . . .
    Now, when I try to hook up the surround, I've got only 1 of my front L/R speakers working. .
    I've hooked them up in all different PL connections, changed it all through the connections menu. .
    It just won't get both of the BL 5s in front going? Anyone have any ideas?
    MJM
    I'm ready for something new that I actually want to buy!
  • 02-15-2009 10:31 PM In reply to
    • mjmedlo
    • Arkansas, USA
    • Posts 384
    Re: beovision 9 help
    I guess my question is. . .do you have to tell your BV 9 that the 7-4 is the centre?  I don't have the option. . the 7-4 shows up on the connections panel, but I can't choose center?  Do i leave it as NONE under the speaker type?
    I have sound from the 7-4, the BL 5 on the left, and both BL 4s in the rear. . .
    Any help is appreciated. .
    thanks
    MJM
  • 02-16-2009 1:13 PM In reply to
    Be sure you toggle completely down the speaker choice menu.  Whe sound comes out of the RT speaker, that is the correct menu choice.
    Barry
