Latest post 07-14-2009 8:14 PM by paddy2042. 5 replies.
Page 1 of 1 (6 items)
  • 07-13-2009 10:34 PM
    BV 8-40 PC connection
    I have connected my Mac to the VGA on the BV8 and picture is fine. I have connected a Black and Red RCA to 3.5mm headphone jack to my Mac's headphone outlet for sound but cannot get any. When I go to Connection menu I choose AV3, PC, VGA and the only sound option I get is P/S dif! How do I choose the Red and black outputs (Is it component?)
    I have previously used this setup on a Sony Baravia and it worked brilliantly.
    Cannot get any sound through the BV 8 however. Am I missing something?
    Patrick
  • 07-14-2009 1:50 AM In reply to
    • Bieele
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Netherlands
    • Posts 339
    Re: BV 8-40 PC connection
    I think you need to connect the sound-output (L/R) to the AV3 scart.
    Regards,
    Bieele
    Heej zuij der alles veur gaeve En heej zaet ze mogen ut hebbe van meej
  • 07-14-2009 3:49 AM In reply to
    So what are the red black and yellow RCA plugs for? I don't see any reference to them in the connections menu.
    Patrick
  • 07-14-2009 7:31 AM In reply to
    • jonasrosen
    • Not Ranked
    • Joined on 07-30-2007
    • Stockholm, Sweden
    • Posts 21
    I'm not sure if this helps, but I had my BV7 and Beomedia1 connected as you described, minijack and L/R in the BV7 and it worked.
    My BV8-40 and my Beomaster5 is connected using vga (only works on AV3) and audio using RCA L/R (BM5) to RCA L/R (BV8).
    I will check tonight at home how it looks like in my connections menu.
    BV8-40, BV7-32, BL7-1, BS5, BM5, BM1, BL3, BS1, Beocom4
  • 07-14-2009 3:43 PM In reply to
    • jonasrosen
    • Not Ranked
    • Stockholm, Sweden
    • Posts 21
    Just to confirm my above post, now I have checked my connection. BV8-40 using L/R RCA from BM5 to L/R RCA BV8-40, VGA. In the connection menu it says AV3, source PC, IR none, HDMI none, YPbPr none, VGA yes, S/P-DIF none.
    And it works, seems it automatically finds the audio / sound somehow.
    Hope it works!
  • 07-14-2009 8:14 PM In reply to
    Thank you seems to be working now OK.
    Patrick
