Latest post 02-08-2009 3:33 AM by JC. 8 replies.
Page 1 of 1 (9 items)
  • 02-07-2009 9:27 AM
    • JC
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Yorkshire / UK
    • Posts 621
    Lab 8000 drivers dead
    Just got some Lab 8000s and all 4 drivers are dead. No splits at all, although slight grating on gentle pushing in of the cone edges. Seems no power is going to them at all.
       They were previously only used as rear speakers in surround set-up so not hammered.
       Any thoughts?
       Jonnie
  • 02-07-2009 10:01 AM In reply to
    Re: Lab 8000 drivers dead
    Jonnie,
    Do you mean the 4 bass drivers? (2 per speaker)
    Sounds weird that they would have died on both speakers. Do you loop the signal trough one speaker to the other?
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 02-07-2009 10:12 AM In reply to
    • JC
    • Yorkshire / UK
    • Posts 621
    Yes the bass drivers.
      No I have tested them individually and both are dead. The tweeters are both working, very strange.
    Jonnie
  • 02-07-2009 10:13 AM In reply to
    Strange indeed. Could there be a fuse blown? They have different amps for treble and bass. If the bass amps fuse went bust on both at the same time?...
    Speculating here.
    -Andreas
  • 02-07-2009 10:52 AM In reply to
    • JC
    • Yorkshire / UK
    • Posts 621
    I am hoping it is a fuse or a cut out, something simple would be great.
      Jonnie
  • 02-07-2009 10:56 AM In reply to
    You can download the service manual. There seems to be two fuses.
    -Andreas
  • 02-07-2009 4:14 PM In reply to
    • JC
    • Yorkshire / UK
    • Posts 621
    Yes I have done so, just seems inplausable that both would go at the same time.
      Jonnie
  • 02-07-2009 4:45 PM In reply to
    Well if they both received some kind of "rough" handling at some point?
    If they've been used as rear speakers, the previous owner probably never noticed anything? Since the information sent to the rear channels is very limited, especially if used in a older pro logic system.
    -Andreas
  • 02-08-2009 3:33 AM In reply to
    • JC
    • Yorkshire / UK
    • Posts 621
    Thanks Andreas for your input.
      Jonnie
