Hi to All,
does anybody know the HexCode for the ‚LAMP’ (LIGHT:LAMP) command, which is unfortunately missing in the command list of the Beo5 config tool .
Knowing this HexCode and adding it to the file ‘IR Command table.xml’, I hope to enable this function on my Beo5.
Any suggestions/ideas?
Thanks in advance for Your help!
