Latest post 02-04-2009 1:29 PM by Roger. 4 replies.
Page 1 of 1 (5 items)
  • 02-03-2009 10:33 PM
    • mjmedlo
    • Top 150 Contributor
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    stb bracket for bv9; 720p model
    Has anyone installed the STB bracket on the back of a 720p Beovision 9?
    If so can you send me a picture, I'm just curious how it all goes together. . .
    thanks
    MJM
    I'm ready for something new that I actually want to buy!
  • 02-04-2009 2:53 AM In reply to
    • Roger
    • Top 75 Contributor
    • Joined on 03-28-2007
    • Norway
    • Posts 870
    Re: stb bracket for bv9; 720p model
    The BV9 comes with four holes pre-drilled for the STB cover/bracket, but the first few models didn't have them pre-drilled - which isn't a major challenge. I have one installed, and it is very convenient to access (snap off cover) and, as it is placed directly above the BS3, cable management it very easy.
    Roger
  • 02-04-2009 6:50 AM In reply to
    This information is freely available on the STB website, wasn't that a good place to start?
  • 02-04-2009 11:59 AM In reply to
    • mjmedlo
    • Arkansas, USA
    • Posts 384
    the stb website showed the new bracket. . .i have the older one;
    thanks roger. . . .would you mind sending me a picture of your install?
    I'm reluctant to drill holes in the bv9. .
    thanks
  • 02-04-2009 1:29 PM In reply to
    • Roger
    • Norway
    • Posts 870
    Just checked with B&O - only the first 300 BV9's didn't have them. I do understand that you are reluctant to drill the holes, I took a couple of pictures but they didn't tell anything but the fact that I need remove some dust from the back of the telly Big Smile
    You can ask your dealer for a quick guide: A "Drilling and mounting instruction" (3543481), which will guide you through the drilling of new holes and how to mount the STB Cover on the back of BeoVision 9-50. It comes with four screws (4 x 2013081), for safe mounting of the STB Cover. They have supplied these free of charge to owners of the first 300 sets.
    Roger
