Latest post 02-03-2009 9:47 PM by Dave. 8 replies.
Page 1 of 1 (9 items)
  • 02-03-2009 2:17 AM
    BV1 LS - no option to change sound
    I bought a cheap BV1 LS with high stand Smile
    But in the Menu there is not a sound option
    So I can not store soundlevel when it comes on
    Anyone??
    Typenr: 8650 SW. 2.3
  • 02-03-2009 10:56 AM In reply to
    Re: BV1 LS - no option to change sound
  • 02-03-2009 11:01 AM In reply to
    No idea I'm afraid - but I just wanted to say that those are two nice shots ;)
    Hi:
    I have exactly the same televiosn yet mine does have a sound menu. I am currently working but would be able to go through my TV menu with you at around 8pm UK time to see if you have a fault.
    Wild guess: What remote are you using, the Beo4 or the one that was shipped with early beovision1's (the one with no number pad) if the latter this maybe where your problem lies.
    Graham
  • 02-03-2009 3:39 PM In reply to
    • hebo
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Sweden
    • Posts 305
    What a cool telly and in such a perfect colur.
    Nice work, is it with motorstand?
    Are you using Beo 4 & 1?
     BV10
  • 02-03-2009 3:54 PM In reply to
    Try to put him on option 1  and maybe will appear.
    Or if not, try to connect extra beolab speakers and see what will happen.
    Or try to reset to fabric default. Menu + 00 + Go , and than monitor service menu and than reset to default.
    But be carful last one will erase all your chanels and settings ...
    when your Black Label begin to taste like juice just take shot or two of Absinthe and after that quench with some vodka, if you still feel juice like take beer with grappa !
    Yes motorstand and Beo4 and Beo1 works but in differents Option
    Painted by my self and order a black speakerclothes
  • 02-03-2009 4:21 PM In reply to
    • Soren
    • Not Ranked
    • Joined on 05-04-2007
    • Kolding Denmark
    • Posts 56
    I have the same tv in my bedroom, it is not possible to store the startup volume, it starts up on a average soundlevel based on the listening volume. My TV start on 18-20, when i used it in my livingroom before i bought my BV7 the start volume was 30-32.
    On the later model there is a sound menu.
    If you want to change the picture settings you also have to enter the service menu.
    Søren
  • 02-03-2009 9:47 PM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    The  speaker cloth needs to be made white!!!!! Don't you think?
    Sound options only on BC1 i thought...
    I have a secret way of hiding those cables where the unit sit's on the pole...
