Apologies for crashing the main forum, but does anyone know if the Peerless 830667 woofer is a straight swap for the original Peerless woofer in the MC120.2? I've got a double case of foam rot, and a toasted coil on one of my drivers, and I just want to get it sorted asap! The link to these is below:
http://www.audio-components.co.uk/store/productdetail.asp?ProductID=16
TIA
John
