Latest post 01-26-2009 3:24 PM by Steve at Sounds Heavenly. 7 replies.
Page 1 of 1 (8 items)
  • 01-22-2009 2:46 PM
    • kimhav
    • Top 500 Contributor
    • Joined on 09-03-2007
    • Sweden
    • Posts 127
    Powerlink installation
    Quick question; what would be the suggested way of installing powerlink cable; ring or star installation? What are the thoughts here?
  • 01-22-2009 2:50 PM In reply to
    Re: Powerlink installation
    Maybe this can halp:
    http://www.beoworld.org/beotech/index.htm
    when your Black Label begin to taste like juice just take shot or two of Absinthe and after that quench with some vodka, if you still feel juice like take beer with grappa !
  • 01-22-2009 3:10 PM In reply to
    • kimhav
    • Sweden
    • Posts 127
    Well, not really. Reason for asking is that my first initial thought was to install a serial powerlink installation for BL8000. But while there are plenty of space I thought of why wiring a star net instead. Also I'm considering in the near future to add a BL2 and noticed that the BL8000 is needed to be looped via BL2; hence the thoughts of wiring a star net instead of a serial.
  • 01-22-2009 3:14 PM In reply to
    Then maybe this :
    http://soundsheavenly.co.uk/bando.htm
    Guy is called Steve and he is also member of this forum, you can email him and I'm sure he can halp you and even make cable for you.
  • 01-23-2009 12:06 PM In reply to
    • Christian
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Copenhagen, Denmark
    • Posts 626
    kimhav:
    It is not necessary to loop through the BL2 if you have a BeoVision with Surround Sound. I do not know if that is an option for you. Smile
    Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
    Addicted? Oh no.... ;)
  • 01-26-2009 2:36 PM In reply to
    • kimhav
    • Sweden
    • Posts 127
    Using BeoVision with Surround Sound isn't an option for me since I don't have that; so looping via BL2 is still needed as far as I understand.
  • 01-26-2009 2:48 PM In reply to
    • Christian
    • Posts 626
    kimhav:
    Correct!
  • 01-26-2009 3:24 PM In reply to
    nmartin771:
    Then maybe this :
    Thanks for the mention!
    Yes, I'm happy to help.  The wiring arrangement for both Powerlink and Masterlink can be done via either ring or star topology, but the good news is that in both cases it doesn't matter.  As long as you get the wiring correct (ie. match the correct wires all through the installation) and get the connections secure (ie. no loose joints) then you are free to use whatever wiring layout works for your living arrangements.
    Some installers have preferred wiring layouts, but the main issue is to get good connections and to keep them accessible for future reference, in case you ever have a system fault, or if you wish to make any changes.
    Any questions, please feel free to ask!
    Best regards,
    Steve.
    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
