I have just got a BV10-40 and have a Panasonic DMR-BW 880 Blu-Ray recorder 500gb hard drive as the DVD player.
The PUC control on the BV10 has the Panasonic DMR-BW 550 (or similar) loaded. It also has the generic Panasonic control for a DVD player loaded as well. I can get most of the functions of the recorder to work but cannot for the life of me get the chapter forward/backward on the DVD part to work. I can use direct chapter selection with the numbers but it would be good if I can just jump forward / backwards with the up/down button.
If I change the PUC control to the generic Panasonic player the up/down button works fine.
I have a Beo 5 /Beo 4 and they both good in their own way. Probably the easiest is the Beo4.
Any hints or suggestions would be much appreciated.
Peter
