Latest post 01-26-2009 12:19 PM by jk1002. 4 replies.
Page 1 of 1 (5 items)
  • 01-26-2009 10:36 AM
    • steph
    • Top 100 Contributor
    • Joined on 04-16-2007
    • France
    • Posts 612
    New BeoVision 7 or 8 ?
    My BeoSound 5 should arrive in february and i would like to connect the BeoMaster to the TV.
    I own a BV3 and would like to change for a larger flat screen in order to get "all digital" and increase the resolution.
    With the introduction of the new modular BV7 and the future BV8-40", what can i do ?
    I love both design but my bugdet is limited (5000€).
    At the moment, my sources are SD (cable box and DVD1) but i can upgrade for a HD box.
    What do you think ?
  • 01-26-2009 10:38 AM In reply to
    Re: New BeoVision 7 or 8 ?
    Wait for the BV10
  • 01-26-2009 11:27 AM In reply to
    • steph
    • France
    • Posts 612
    OK,
    but apparently, the BV10 will be priced around 10000$ (7600€).
    Too expensive...
  • 01-26-2009 11:30 AM In reply to
    7600ESad   (mid-level?)
    a lot of money
  • 01-26-2009 12:19 PM In reply to
    I think it was said that it will be below 10K.
    Since it seems that the price of the BV7 MK4 will be lower then MK3 based on comments in the german forum I'd say this is all up in the air.
    I find the modular BV7 very interesting. Since you have the DVD already I would take a close look.
    I actually looked at the BV7 without center as well before I settled on my BV8 and BC2. I couldn't figure out how to get a table stand for it, but I think that now may be sorted.
