Latest post 01-17-2009 9:17 PM by Piaf. 3 replies.
Page 1 of 1 (4 items)
  • 01-16-2009 10:57 PM
    • Piaf
    • Top 150 Contributor
    • Joined on 07-08-2007
    • Victoria, British Columbia
    • Posts 409
    Beomaster 8000 "Issues"
    I have a “general” question about receivers.
    There is a Beomaster 8000 currently for sale on eBay whose owner states that it has been “serviced” and “any 8000 which has not be serviced in the last 8 years will give trouble.”
    Is this true? And if so does the same apply to the “lesser” Beomasters of the era?
    I have a Beomaster 2400 that gives absolutely no clue that it is in need of anything in the way of service…. it just performs like a champion.
    Ditto my Beomaster 4500, which I accept will at some point need new caps, but at present, now that I am not forcing it to power speakers with shorted-out connections, performs beautifully.
    So is the Beomaster 8000 different in this regard, or was the owner exaggerating the need for frequent service?
    Also, in regard to this same Beomaster 8000, the owner stated that several LED’s no longer light and there is nothing to do about this until replacement parts are made available. Is this situation any different from the Beocord 8000 series recorders that have problems with their LED’s? As I understand it, it is a solder issue not an LED issue.
    Your thoughts, if you please.
    Thanks,
    Jeff
  • 01-16-2009 11:26 PM In reply to
    Re: Beomaster 8000 "Issues"
    i find it hit or miss... had items that were cosmetically perfect, but shot cap wise... and viceversa... ugly stuff that was just fine electronically!
    re: "lights" form that era:
    http://forum.beoworld.org/forums/thread/17489.aspx
    apologies in advance... "links" do not work for me on the logged in browser...
    • B&o bottle opener
  • 01-17-2009 7:58 AM In reply to
    I think Dillen can give the best answer on that as he has done alot.
     The Beomaster 8000 is a complicated machine with alot of electronic devices from a service point of wiev.
    The more complicated the more it heads for trouble. Being the age that its from (1981) its no wonder that every Beomaster at some point needs service. Keep in mind that when the units perfom perfectly the get alot of use and the only reason alot of the older B&O comes up for sale is the fact it needs service and most people don't know where to go.
    If the Beomaster 8000 is done well it well last long. Mine was a bit time consumming as there was alot of different adjusments to do due to unqualified former service. I use it on a day to day basis and exept a tiny bit of loose connections comming up it works great.
    As I learned getting into the Beolab 8000 and 6000 for that matter is that its a step up but if you dont have a repairman on hand its not the best purchase to make.
    As for lights Dillen fixed some in mine so it comes with age and it can be done well. It's just one of many little things that can be trouble in a Beomaster 8000.
    Yes I have heard many cheaper/less complicated Beomasters and the thing with those is there is less to break. That's basically why. My parents Beocenter 2000 is still working. Now half of my white 6000 has replaced it. That is also back to 100% ready for the future.
    I could get my Beomaster 2000 fixed at my local shop for a fair amount and it worked flawlesly the next 3 years. When it came to the 6000 and 8000 he was not able to do it. The Beogram 8002 were nearly dead even after he tried doing service. I took it to Dillen and I got a working as new 8002 back. That one still plays wonderfully nearly every day. I got it back november 2007 and so far just enjoyment.
    I will say that the statement is right. Ad 8 years from now to any Beolab 8000 unit. Beomasteres for sale do show signs of trouble today, Beocords, Beograms likewise and Beox MS has foamrot. The few that has not had service yet will need it sooner or later.
    The trouble is that few people can handle the service. My Beomaster 8000 is proof!
    Unless its serviced its a question of when and that's basically the questions that comes up when one of the few still going is for sale in an ad. Great nice Beomaster 8000 with remote price xxxxxxx. Nothing about service or working condition but to the normal higher price it must be. Is it a better buy? No it will come and 8 years is good guess. One thing to say is that 20 years at least is really good for any stereo and B&O does it well. After that your unit will expire in ?????LOL
    I don't regret a second of the Beolab 8000 time and money spend getting my system. In most cases straight to seller of the unit and then straight to Dillen in Copenhagen before I could even use it at all. The hunt for my Beomaster 8000 were interesting as it blew fuses. What could be wrong? Can't say 100% untill it's on the workshop table but Dillen gave me a sort of how complicated the worst case scenerio could be. Still I was curios and since a CDX also dead were with it I went for it.
  • 01-17-2009 9:17 PM In reply to
    • Piaf
    • Posts 409
    After posting this open question, my ever-dependable Beomaster 2400 began giving off an odor of electrical fire mixed with hot oil.
    There is no distortion in the sound and no problems with any controls…. Just the smell.
    I am thinking that some transistors or capacitors are in the process of failing.
    What do you think?
    Jeff
