I saw also that you can buy it on ebay, but i have all the stuff in house, so that's why i want to make it myself.
But do i only need to connect the signal gnd (pin 2), audio signal (pin 3 left, pin 5 right audio) and shielding (pin 7) of the cable. Or do i need to do something with the PL ON (pin 1) and PL speaker ON (pin 4) or can i just leave them floating or Ground them?
thanks a lot
Guy
