Hello
This is my first post on here, and sadly its a few stupid questions...
Is it possible to connect non-B&O equipment (eg. VCR or DVD player) to a B&O television? I can only afford to buy a TV right now, not even sure I can manage that but hey ho, and I want to use it as a standalone piece within my existing setup. Is this doable?
What is the difference between an MX4000 and a 4002/4200? I know the 4002/4200 have Beolink, but what difference will that make in laymans terms?
My parents had a Beovision 7700 when I was small, and it died, to be replaced by a Sony. The untimely demise of the B&O was brought about I seem to remember by dry joints. Does this sound likely, and is it likely to afflict the more modern B&O tube televisions (Avant/MX/Beovision1/Beocenter1)?
Have read on here that the bottom has fallen out of the prices of B&O tube televisions of late. How cheap are we talking?
Like I said, probably all dumb questions! My first, and only so far, bits of B&O are a Beomaster 901, Beocord 900, A pair of S30s and a Beogram 1203 (which isn't currently working), so a little bit less technologically advanced than the televisions!
Thanks!
