Latest post 01-19-2009 1:45 PM by tournedos. 10 replies.
Page 1 of 1 (11 items)
  • 01-19-2009 6:12 AM
    BeoMaster 5 virus vulnerability
    Is BeoMaster 5 really so virus protected? If I upload all my CD collection and mp3 files that I have uploaded from the internet to BeoMaster 5 and a virus attacks BeoMaster 5 what happens if the virus programme is not efficient? Doe this mean all my music goes away?
  • 01-19-2009 7:01 AM In reply to
    • Beobird
    • Top 150 Contributor
    • Joined on 04-19-2007
    • Netherlands
    • Posts 506
    • Gold Member
    Re: BeoMaster 5 virus vulnerability
    Don't know what kind of software the BM5 uses, but 90% of all virus programms are made for Windows. The other 9,99% is Mac and Linux so the change that there is a special B&O virus is very small.
    We Can't Get Enough B&O Stuff...
  • 01-19-2009 8:18 AM In reply to
    The Beomaster 5 runs Windows XP (Embedded Version) with Service Pack 2 with integrated firewall and an Antivirus programme with automatic updates provided by BullGuard and includes 5 years of updates.
    You can review the Bullguard product HERE
    Regards Keith....
  • 01-19-2009 8:25 AM In reply to
    But what about after 5 years? What happens when there is a virus that gets trough the antivirus programme? How can BeoMaster be cleaned from the viruses? Is there a possibility to run a special anti virus programme via the PC or how?
    Can a virus in BeoMaster also affect the control - BeoSound 5 as there are for instance cowers displayed etc?
  • 01-19-2009 8:33 AM In reply to
    You should avoid using the Web Browsing feature if you are worried of viruses.
    Thanks to the Firewall, it is less likely that viruses could enter the system if as you are not going to infected pages.
  • 01-19-2009 9:02 AM In reply to
    I see you mean the web function. But one question, would you buy the new BS5+BM5 now, or ruther wait a little while?
  • 01-19-2009 9:06 AM In reply to
    The BS5/BM5 that are on display are not the final one, especially in term of software.
    I'd want to see the final sofware/feature set before making my choice.
    p.
  • 01-19-2009 11:07 AM In reply to
    I think there are two factors in play here at present.
    First, if you use your BM5/BS5 "correctly" and have it communicate with the B&O server and only approved N.Radio channels as designed, then I see the risk as very very small indeed. If your going to be unwise and use your BM5 for surfing the web, then after 5 years your simply asking for trouble. Use your standard PC for that. It will be better set-uop with mouse, keyboard etc....
    The Second factor is if B&O are going to use a standard digital platform with regular updates for most of their new PC-based products, then AV guards will be commonplace and it is highly likely that once you buy a product, it will be protected for the life of that product.
    10%
  • 01-19-2009 12:26 PM In reply to
    Why is the Update service limited to 5 years ?
  • 01-19-2009 1:39 PM In reply to
    erg4000:
    $$$$$$Money I think
  • 01-19-2009 1:45 PM In reply to
    erg4000:
    It has to be limited to something (just like spare parts availability is limited). Probably Microsoft has a limit for the support of the underlying OS itself as well, and there's nothing B&O can do about that - when it's gone, it's gone.
    Anyway, I would expect the support to continue even longer, as long as it is feasible to do so. And there's nothing preventing you from performing the antivirus tasks yourself. Simply not using the machine to browse stupid web sites goes a long way towards this goal...
    -mika
