1st March February 2012
Latest post 01-11-2009 4:06 PM by Craig. 13 replies.
01-09-2009 12:37 PM
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Tomorrow I am collecting an Avant 28 VCR, which I will be using in the Bedroom. Do they come apart in any way? At the very least can I remove the stand? Also I am looking for the User Manual for it. Type number 8103, we do not seem to have it on the site. From the products page it is either a MK3 or MK4 50Hz. Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Puncher
- Joined on 03-27-2007
- Nr. Durham, NE England.
- Posts 9,588
Craig: Tomorrow I am collecting an Avant 28 VCR, which I will be using in the Bedroom. Do they come apart in any way? At the very least can I remove the stand? Also I am looking for the User Manual for it. Type number 8103, we do not seem to have it on the site. From the products page it is either a MK3 or MK4 50Hz. Craig
If you go to the Beotech part of the site and look throught the old accessories catalogues you'll find B&O used to do an Avant Bungee strap especially for lashing them onto the pilion seat of your bike!
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
No Craig, they don't come apart. I transported mine in the back of my estate car laid on its back & held in situ with bungee cords to stop it rolling around - and then drove very conservatively There are hand holds at the rear (2 holes at the same height as the lower screen edge) and 2 "indentations" just under each side of the screen surround which give you the correct balance when moving it around. Chris.
Medogsfat
- Posts 4,045
True Graham, which was my original plan but the layout of the back of my estate enabled me to strap the Avant in on its back and strap it to the pull out parcel shelf which lessened the chance of damaging the screen. I'm sure the best way would be to transport one stood on its base in a van and secured to the sides. Chris.
Iconic-AV
- Joined on 04-16-2007
- Birmingham UK
- Posts 902
Hi Craig, Which dealer? I maybe able to collect it for you in the van theres room in the back for the avant, yourself and your bike I'm in London in the morning but should be back late afternoon if you need me. jay
Iconic-AV
- Birmingham UK
- Posts 902
hi craig, If it is somewhere between here and london and you want me to pick it up for you, let me know before 9am so i can plan it into the journeys, you can ring me uptil 11pm incase im not at the pc jason
Craig
- Posts 4,855
Iconic-AV:hi craig, If it is somewhere between here and london and you want me to pick it up for you, let me know before 9am so i can plan it into the journeys, you can ring me uptil 11pm incase im not at the pc jason
Jason, you have a PM. Craig
gk31ax
- Joined on 04-18-2007
- Posts 220
If its and RF version, I took the glass off the TV and transported that seperately...... I laid mine screen down in the back of my A3 which was the dealers advice Drove mine over 200 miles, lots of duvets and pillows to protect it and didn't drive like an idiot... Arrived home in perfect condition Good luck and enjoy your purchase
Dave
- Joined on 04-17-2007
- Brisbane, Australia
- Posts 2,328
well if laying down a CRT It is best to lay it on it's diagonal side to prevent the damage that matt mentioned, (thats why on the B&O boxes they have that little picture showing not to lay it on it's front) it's also possible that fragments can fall from inside the screen and land on the crt grid... can't remember the technical terms
Iconic-AV
- Birmingham UK
- Posts 902
hi craig, ill be with you around 3-4pm, ill give you a call as the day goes on to give you a more accurate time see you later
Craig
- Posts 4,855
Well thanks to Jason's kind offer it will be safely transported upright in his van. Usually I always transport TV's on their screen with an old duvet placed underneath. After moving quite a few TV's this way I have never damaged one. Craig
Page 1 of 1 (14 items)
