Hello Gerd and rest of forum,
Thanks for your information,
I finally contacted the B&O technician for the upgrade cause I did not feel comfortable with this particular upgrade (I did not want to ruin the Avant which I consider excellent), and the first test last Friday morning were great (and I only have 2 beolab 8000 not 5.1). FYI, we connected 1 speaker to front plug and the other to the rear. Beovision is Option2 and Beosound3000 is option 0
However, Friday evening something happened. When we turn on the TV pressing 'SAT' the beolab/front speaker produces a very very high noise (something like SSSSTTTTT but really really strong) and the beolab/rear is off. I have disconnected all the speakers and I will reconnect them tomorrow with the 'Y' splitter once I buy it in B&O dealer.
I have think that maybe it is just the fact of having only 1 beolab connected to the front plug instead of 2. Well, I will have an answer by tomorrow. I will keep you inform (maybe with your experience you have seen something like that or you know what could happen).
Thanks for any help,
Francisco
