Latest post 01-09-2009 1:38 PM by Alex. 9 replies.
Page 1 of 1 (10 items)
  • 01-07-2009 3:44 PM
    • OKF
    • Top 500 Contributor
    • Joined on 02-22-2008
    • Posts 204
    Which MK is my BV 7-40 - how can I find out
    How can I find out which MK my BV 7-40 is bought in 2006?
    Best regards Oliver
  • 01-07-2009 4:38 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: Which MK is my BV 7-40 - how can I find out
    MENU - Options - 0 - 0 - GO (service menu - be careful) MONITOR - GO - Type number.
    New in 2006 should be MK II.
    Stefan
  • 01-07-2009 5:12 PM In reply to
    • V13WNG
    • Joined on 06-11-2007
    • Eastbourne, East Sussex, ENG
    • Posts 200
    Yes, a 2006 model will be MKII.
    Muchos Gracias Cool
  • 01-09-2009 7:44 AM In reply to
    • OKF
    • Posts 204
    it is a 9351 and that should MK 1 but it has the Projector Pin and the DVI-I.
     What is the difference between MK1, 2 and 3 and how can you spot it apart from the number?
    Best regards Oliver
  • 01-09-2009 7:55 AM In reply to
    OKF:
    • MKI vs MKII: MKII is HD Ready. You can convert MKI in MKII, adding a HD Ready Kit.
    • MKIII: Full HD screen and BeoSystem 3 as picture engine.
    Jq. BS4 BL3 A8 Form2
  • 01-09-2009 8:08 AM In reply to
    • OKF
    • Posts 204
    In the instructions it seems to say that if you have a DVI-I port on the TV it is HD Ready or maybe I missinterpret that? I also do not know wghat HD ready and Fall HD really means
    Best regards Oliver
  • 01-09-2009 8:16 AM In reply to
    Yes, there is a DVI-I input, but for computers. For the HD (high definition) signals you need to change the DVI-I input to a DVI-D input with HDCP to see HD signals. This is one of the features of the HD Ready Kit.
    The diferences of HD Ready and (bad called) Full HD is the numbers of pixels of the screen:
    • HD Ready: 720/768 lines
    • Full HD: 1080 lines
    The diferences in picture quality depends on the eye that look at Stick out tongue
  • 01-09-2009 9:34 AM In reply to
    • OKF
    • Posts 204
    so I guess that kit replaces the part where the DVI-I port sits and should not be overly complicated to swap? Where can you get such kit, how expensive is it and does it make sense to switch mk1 to mk2?
    Best regards Oliver
  • 01-09-2009 9:39 AM In reply to
    You can order it to a B&O dealer. The price in Spain is about 350 €...
  • 01-09-2009 1:38 PM In reply to
    • Alex
    • Top 25 Contributor
    • Bath & Cardiff, UK
    • Posts 2,990
    I wouldn't say it's not so simple, there are quite a few chances to (majorly) screw things up inside the TV in the process of doing it. You do it at your own risk if you want to.
     Weekly top artists:
