Latest post 02-05-2009 1:47 PM by Chrisreunion. 10 replies.
Page 1 of 1 (11 items)
  • 02-05-2009 2:52 AM
    BeoSound 5 and BeoPort
    Can BeoSound controler be connected to BeoPort so no BeoMaster 5 is needed and mp3 files can be listened directly from computers hard drive?
  • 02-05-2009 3:28 AM In reply to
    Re: BeoSound 5 and BeoPort
    No...
    Every other B&O hifi can, but no Beosound 5.
    Beosound 5 is in fact just a LCD screen and a Wheel. There is no intelligence in it so it cannot do anything on its own.
    p.
  • 02-05-2009 3:45 AM In reply to
    Hi
    I'm still struggling with the point of beosound 5.. if you infact already have beoport.?
    Why not connect your beoport and computer up to your beovision and have  a beautiful display of itunes cover art/net radio in your living room..
    I've recently bought a mac mini connected up to my tv and beoport and it works beautifully. Beoport is all most obsolete now but I do like to see the tracks displayed on the beocentre 2 (when i dont want the tv screen on in pc mode).
    Happy to be corrected if ive missed something... I guess you'd buy beosound 5 if you didn't have beoport??
    Regards
    David Coyne
    Sydney, Australia
    BV8-40, BC6-26, BC2, Beolab 9's, Beogram 7000, Beogram 9500, Beoport, Beotalk 1200, Beocom 6000, Beolit 1000, 800, 700, 600, 400
  • 02-05-2009 4:25 AM In reply to
    yes...the sound quality!
    The difference between BeoPort and the BM/BS5 is simply incomparable.
    If you want to listen through your PC soundcard and mini-jack, then fine. Beoport does offer a good value way of doing this and integrating into your B&O system.
    I have just relinquished my BC2 and had to use the Beoport and my noisy PC for a couple of months (I know..all your hearts bleed) but I became deeply irritated with the sound and the regular blips in music as the PC tried to keep up with lossless.
    The BS5 acts as a hi-fi and the user is simply unaware that you have a PC in your living room. No blowing fans, no illegal beeps, no blips in the music. Just seamless.
    Having a BS5, I am still struggling to come to terms with the expense of the thing but the more I use it, the more I wonder what did I ever do before?
    10%
  • 02-05-2009 5:09 AM In reply to
    I was thinking of the BeoPort solution with my 7-40 but to be honest I don't like the thought of the TV staying on for long periods just displaying cover art! My mindest is probably still trapped in the olden days of tube televisions and wanting to conserve B&O hours on the set in case I ever sell it on or trade in at a later date. I only really want to use the TV for TV channel watching!
    I like the BS5 a lot but I have almost finished rennovating my home now so all cabling has already been done and the BS5 was not around, neither did I know about it when I started my project 18 months ago. If I was prepared to start digging channelling and replastering all over again then the BS5 would definitly be the choice.
    Simon.
  • 02-05-2009 8:44 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    You'll understand what the BeoSound 5 is about once you've used one - it's not something which can easily be explained in text...
     Weekly top artists:
  • 02-05-2009 10:39 AM In reply to
    • steph
    • Top 100 Contributor
    • France
    • Posts 612
    Reading all your comments, i'm getting very impatient to get mine ! Embarrassed
    I think it's a very special user experience !
  • 02-05-2009 10:45 AM In reply to
    @ Beonic: I am hoping that when the 2 way remote comes, that it works of the Beomaster 2 not of the Beosound 5. That way the cabling would not be that much of an issue. You just hide the master box somewhere and have the remote floating around.
    Personally I don't have a way to add the BS5 to my setup and make it look good. And As yourself I don't want to open walls to hide cables. A Beomaster 5 with a wireless 2 way remote though would be something that would work.
    JK
  • 02-05-2009 10:54 AM In reply to
    You can use the BM5 on its own, through the TV...
  • 02-05-2009 10:58 AM In reply to
    Yes, but I would not want the TV to be on. Beomaster and 2 way remote could be a very good solution.
  • 02-05-2009 1:47 PM In reply to
    After reading the complete user guide for both BeoSound & BeoMaster 5, I decided to buy a wireless keyboard and mouse, connect my PC to my BV7, and run BeoPort throughout the house via Masterlink of course.
    The sound improvement on a BeoMaster 5 may be a good reason to buy it, but frankly, with an external soundcard fitted with both digital (for BV7) and analog (for BeoLink) outputs, with 24bit converters,  I'm not sure one could hear a difference when playing lossless WMA via digital output for serious listening, and via analog output on a BeoLab 2000...
    And at least, I can use my laptop as a real PC with BV7 as the monitor, something BeoMaster 5 can't do, so you eventually end up with 2 boxes under or behind the TV, and 2 sets of cables instead of 1.
    But of course what is good for me may no be good for others!Smile
    Reunion Island is greeting you!
