Latest post 01-07-2009 3:26 AM by Nis. 3 replies.
Page 1 of 1 (4 items)
  • 01-06-2009 7:16 AM
    • Nis
    • Not Ranked
    • Joined on 08-13-2008
    • Roskilde, Denmark
    • Posts 30
    How to connect a DIN speaker plug to cable
    I have just got hands on a pair of old Beovox speakers. Unfortunately they came with no speaker plug attached to the cable. The speakers have to be connected to a Beomaster 4000.
    I remember from my younger days I were connecting a 1.5 Volt battery to the cable, and if the speaker were moving forward, I should connect the wire from the plus-pole to the ... pin.  Well, I can’t remember.
    So question is, how do I correctly connect the two wires to the two pins in a DIN plug. How to figure out, which wire go to the round pin and which to the squared pin? Or plus and minus?
    Regrads
    Nis
  • 01-06-2009 7:27 AM In reply to
    Re: How to connect a DIN speaker plug to cable
    Conventionally, the round pin is positive (+) - I think the cone moves outwards then. Anyway, it doesn't matter which way they are, as long as both speakers are connected in the same way. Unfortunately B&O cables typically look completely symmetrical from the outside, so you'll have to do the battery test (or open the speaker and look/measure).
    Trial and error is another possibility. If the speakers are connected differently, particularly the bass end will sound like crap (most audible when the speakers are closely side by side). Then just swap the wires in one of the connectors.
    -mika
  • 01-07-2009 3:26 AM In reply to
    • Nis
    • Not Ranked
    • Roskilde, Denmark
    • Posts 30
    Thanks a lot Peter.
    It was exactly that information I was looking for.
    Best regards
    Nis
