Latest post 01-05-2009 8:07 AM by Evan. 10 replies.
Page 1 of 1 (11 items)
  • 12-15-2008 1:42 PM
    • C_K
    • Not Ranked
    • Joined on 12-15-2008
    • Posts 3
    Beogram CD 4500 - odd noise
    Hi, has anyone had this problem before:
    My Beogram CD 4500 spins and reads CDs fine but the output is just a hiss with slight variations in the hiss level.  There is no music playing.  I know it's reading the CD because when I put in a "dummy" CD, it doesn't read it.  Also, the motor moves when you change tracks etc.  Plus I can see the laser is on (when no CD is in).
    Any ideas what it could be?  Any clue would help.  Thanks.
  • 12-17-2008 10:04 AM In reply to
    • Evan
    • Top 25 Contributor
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: Beogram CD 4500 - odd noise
    I also have a beogram cd 4500, but I am sorry to say that I cannot help you here. My beogram has a few odd noises but no hissing. I will let you know if I come across anything that might be of service to you.
    Evan
  • 12-17-2008 10:51 AM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    By the way, would you happen to know how to properly utilize the digital output on the BG CD 4500? Do you know if it has any benefits over the provided DIN/multi-pin connector?
    Evan
  • 12-17-2008 2:11 PM In reply to
    • C_K
    • Not Ranked
    • Posts 3
    Thanks for the reply.  I haven't tried the optical output but that just gave me an idea.  I'm guessing that it should connect with an optical input on other stereo components.  I'm going to try that output with a different brand receiver and see if that works.  I'm also thinking of getting a DIN to RCA connector and trying this CD player on a different receiver to make sure the CD input on the 5400 receiver is not malfunctioning.  I'll update how this works in a few days.
  • 12-17-2008 7:16 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    No problem. In a way this is similar to what I have... A hybrid of components haha. I will soon be purchasing a plethora of RCA adapters myself. I am curious as to how this pans out for you.
    Evan
  • 12-30-2008 1:27 PM In reply to
    • C_K
    • Not Ranked
    • Posts 3
    So here's an update on the digital output of the CD player.  My mistake, it's an RCA, not an optical.  I connected it to a different receiver with it's own DAC and it works with that.  Then I connected a different CD player to the B&O receiver and that worked fine too.  So the problem must be with either the muting circuit (from what I've read on this forum) or the DAC.  I'm going to subscribe to get some manuals and try to solve this soon.
  • 01-02-2009 12:49 AM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Glad to hear of your progress. I think i noticed it was an RCA but I need not bother with it as my multi - pin connector is without flaw. Before you go to such lengths with the manuals, check out the official B&O forum. I myself have attained a few manuals from they're community downlads site.
    Evan
  • 01-02-2009 11:09 AM In reply to
    • Kokomo
    • Top 100 Contributor
    • Joined on 08-21-2007
    • Spain
    • Posts 618
    C_K:
    I seem to recall my CD4500 had an optical out. When I telephoned B&O to find out how I could make use of it via my Beomaster I was told I couldn't as the CD4500 had the socket only, there were no electronics behind it!
  • 01-02-2009 8:59 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Interesting. At any rate there is an RCA output that I believe says "digital output" above it. I am not near it now so that may be slightly incorrect.
    Evan
  • 01-03-2009 5:20 AM In reply to
    • Kokomo
    • Spain
    • Posts 618
    evman140:
    Yes you're correct, my memory was playing tricks. It did say digital output above the socket, not optical.
    Didn't change the result that it was useless though! A bit disappointing at the time to say the least for what was an expensive piece of kit.
  • 01-05-2009 8:07 AM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    The only thing that i see as odd is the fact that all my other CD players (Non B&O) of the same era have both left and right RCA signal jacks/outputs. Why doesn't this carry over to the BG CD 4500?
    Evan
