Latest post 01-04-2009 11:09 AM by Peter. 2 replies.
Page 1 of 1 (3 items)
  • 01-04-2009 10:57 AM
    • jc
    • Top 500 Contributor
    • Joined on 11-06-2007
    • The Netherlands
    • Posts 145
    Beocenter 2300 vs Beosound 3000
    Thinking about buying one of these sliding door-systems (second hand), are there any arguments in favor of the 2300 or 3000? I read something about cheap plastics used, did these materials upgrade over time in the 3000? Any differences in sound or quality of the CD player used?
    George
  • 01-04-2009 11:05 AM In reply to
    • AdiS
    • Joined on 07-24-2007
    • Posts 196
    Re: Beocenter 2300 vs Beosound 3000
    the 3000 has Masterlink-Connection, the 2300 only via Converter!
  • 01-04-2009 11:09 AM In reply to
    The major advantage of the 3000 is that it has an ML connection and can work with N.Music in most cases. The early 2300s have two way communication. I don't think the quality of construction changed much though the DAC changes from a 16bit in the early 2300s to Bitstream. Some prefer the 16 bit devices for sound.
