        1st March February 2012
	    Latest post 01-03-2009 6:23 AM by  k984942. 16 replies.
									        Tayne
								                - Joined on 05-31-2007
								                - Posts 23
										    Re: Virgin V+ STB and Avant DVD
										    This is possible (V+) depending on the version of Avant (Only the later ones) It is avalible in the leatest PUC software
									        Peter
								                - Joined on 02-12-2007
								                - Posts 9,572
										    I will need to check, but it is a RF Avant DVD32". He said about 5 years old though I imagine a year or so older could be possible. He was told that the software was only for the flat screen TVs and not the Avant.
									        Keith Saunders
								                - Joined on 04-16-2007
								                - Technical Advisor, Little Ann, Hampshire, UK
								                - Posts 3,810
										    Peter, The Virgin V+ box is made by the US company Scientific Atlanta Explorer model 8300HD which is also used under the TeleWest name as well. This actual STB is not available in any version of AVANT STB chipset, however as Scientific Atlanta appears to use the same IR codes for all their STB's, you could try the "G Sci Atl DVR" listed in the "Western Europe" version 4.01 chip part number 8344785 or "SciTiAtla SABNNKZNS" listed in the "Southern Europe" version 4.03 chip part number 8344787
									        Peter
								                - Posts 9,572
										    That sounds good! I'll let him know! He was pretty cheesed off and was threatening to sell all his B&O kit. he did buy a Sony LCD though for another room and found the broadcast picture very poor compared to the Avant - no surprise there then!
									        Peter
								                - Posts 9,572
										    If these didn't work, can you get a Beo5 to operate it independently?
									        Keith Saunders
								                - Posts 3,810
										    Peter, Making Virgin V+ work directly with the Beo5 is very easy because it uses Philips RC5 IR protocol codes, so an XML file can be created with our "Beo5 3rd Party XML Generator"
									        Peter
								                - Posts 9,572
										    I had a suspicion it might - I have offered to lend him my Beo5 if the other codes don't work. Afraid still a paperweight though I have charged it!
									        k984942
								                - Joined on 11-10-2008
								                - London, UK
								                - Posts 194
										    Hi All I have the latrst STB-C in my Avant (4.01 West Europe) and wish to control my Virgin V+. If I select the  G Sci Atl DVR as the source: 1. Every time I  do anything (e.g. change channel or look at TV guide) the picture freezes for a fraction of a second. 2. I can't utilise the coloured buttons as they are mapped to do other things like go up and down channel.  3. I can't access the menu to view my recordings  I therefore tried the Pace 4000 NTL as the source: 1. No temporary freeze of picture what so ever 2. Full use of the coloured buttons as they are not mapped to do other things. 3. I still can't access my recordings!!   Can anyone let me know what sourced they've chosen so as to control their Scientific Atlanta Explorer, and which Beo4 keys do what? As always, your help and support is greatly appreciated.
32" RF VCR Avant, 2 x 28" VCR Avant, DVD1, Beocom 6000, Beo5, A9 Keyring!
									        johnnysenna
								                - Joined on 07-31-2007
								                - Posts 4
										      k984942: Hi All I have the latrst STB-C in my Avant (4.01 West Europe) and wish to control my Virgin V+. If I select the  G Sci Atl DVR as the source: 1. Every time I  do anything (e.g. change channel or look at TV guide) the picture freezes for a fraction of a second. 2. I can't utilise the coloured buttons as they are mapped to do other things like go up and down channel.  3. I can't access the menu to view my recordings  I therefore tried the Pace 4000 NTL as the source: 1. No temporary freeze of picture what so ever 2. Full use of the coloured buttons as they are not mapped to do other things. 3. I still can't access my recordings!!   Can anyone let me know what sourced they've chosen so as to control their Scientific Atlanta Explorer, and which Beo4 keys do what? As always, your help and support is greatly appreciated.
     Hi, just wondered if you have had any joy with this yet?
									        johnnysenna
								                - Posts 4
										      Peter :I had a suspicion it might - I have offered to lend him my Beo5 if the other codes don't work. Afraid still a paperweight though I have charged it!
   I am Peter's mate, it's my problem we are trying to fix. Thanks for all your help so far everyone.  Will the Beo5 happily work a V+ box that is stuck to the back of my Avant? Will the infrared signal get to the V+ box back there?
									        Keith Saunders
								                - Posts 3,810
										    As with all infra-red remotes, the receiver has to see the signal, so if it is behind the AVANT it is unlikely to see the Beo5 signal. Given, that it is unlikely that you would wish to move the Virgin box from behind the AVANT, then you may wish to purchase a cheap infra-red extender, where you have a small IR transmitter in front of the Virgin box and the small receiver where it can receive the IR signal from the Beo5.
									        johnnysenna
								                - Posts 4
										      Keith Saunders: As with all infra-red remotes, the receiver has to see the signal, so if it is behind the AVANT it is unlikely to see the Beo5 signal. Given, that it is unlikely that you would wish to move the Virgin box from behind the AVANT, then you may wish to purchase a cheap infra-red extender, where you have a small IR transmitter in front of the Virgin box and the small receiver where it can receive the IR signal from the Beo5.
   Thanks for the advice. There have been developments!! I have cancelled my new Virgin account with no penalty. I will hopefully be installing Sky + instead. Might stick with Virgin for phone ahnd broadband, but those are mere details. Many thanks for the advice. Will go to see Peter's Sky + in action on his Avant if I can arrange that with the old chap. ;)
									        k984942
								                - London, UK
								                - Posts 194
										    Haven't gotten anywhere unfortunately!   I'm still hoping there's an alternative to buying a Beo5! Wish I could switch to Sky but I'm stuck in my contract I'm afraid
									        Keith Saunders
								                - Posts 3,810
										    Assuming your Virgin remote control works perfectly with your Virgin box and you are sure that the STB IR transmitter is correctly placed over the Virgin Boxes IR receiver, then the only assessment can be that the STB controls are not compatible with your STB. As you have the latest chipset in your AVANT and B&O will no longer be providing STB updates, then you are left with three (3) options:- - Change from Virgin to Sky
 - Purchase a Lintronic box and let it drive the Virgin box taking its signal from pin 8 (AVL) on the SCART
 - Purchase a Beo5 and control the unit directly
 I guess there is a forth option, but unlikely one you would consider and that is to purchase a Beovision with a PUC which can be software updated for the Virgin box.
									        k984942
								                - London, UK
								                - Posts 194
										    Thanks for your help as always Keith. I guess its a Beo5 for me then!   Has anyone in the UK managed to get a good deal on one sine the dealers are struggling at the moment? They don't seem to come up on the second hand market very often.
        Page 1 of 1 (17 items)
