Hello Martin
Generally when I put oil on motor axle the toneram is moved at the starting point of record. When I put << key I can move the toneram but it isn't smoothly, in some cases toneram run with pluck.
Before applied oil the tomeram was moved at the starting point of record but when I putted << key it wasn't move and after about one second the < indicator lighted very weakly. I think that it was effect that the force from my inadequate belt is too high. I hope that servo motor is OK.
Coudl you inform me what will be a cost of belt for Beogram 8002 and also the both belts for Beogram 5005 ( I have the old items in my second Beogram) with shipment to Poland.
My email ***.pl
Best Regards
Tomasz
