Latest post 12-28-2008 2:15 PM by Kelle. 4 replies.
Page 1 of 1 (5 items)
  • 12-19-2008 4:06 PM
    • Kelle
    • Not Ranked
    • Joined on 07-21-2008
    • Posts 4
    • Gold Member
    MX4200 VS. BeoSound 3000
    Hey!
    I have a Avant 28" and a beosound 3000 working together through a master link. I have recently put up a MX4200 in my bedroom and added the masterlink module to it. I am, however not able to use either the beosound 3000 features through the MX4200 or the VCR from the Avant. Is there something I should "turn on" on the MX4200 to get this working?
    Best regards,
    Søren, Denmark
  • 12-19-2008 4:57 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: MX4200 VS. BeoSound 3000
    Sounds as though the MX4200 needs to be put into option 6. Press 'Standby' and 'LIST' at the same time on your Beo4 in the same room as the 4200. Then use the 'Up' and 'Down' arrows on the Beo4 to get through to OPTION? on the display. Press 'Go'. Again, using the arrows, get 'V.Opt' on the display. Press 'Go' and press '6'. The standby light on the 4200 should blink to signify that it's received the option command. The CD/Radio/A.Aux/VCR functions should now work. Smile
    Also, make sure there aren't any conflicting sources in the 'connections' menu in the 4200.
     Weekly top artists:
  • 12-19-2008 6:25 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Hi and welcome to Beoworld. It might be worth you looking at the Materlink guide. As a gold member you can download it HERE.
    CraigSmile
  • 12-19-2008 7:18 PM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Laughing Why are the languages other than english 5 times the size? lol
     Cheers for the link i've been having some confusion with master link myself
  • 12-28-2008 2:15 PM In reply to
    • Kelle
    • Not Ranked
    • Posts 4
    • Gold Member
    Thanks for you kind answers.
    I have now managed to get the MX4200 to play both radio and CD. I tried to give it option 6 with Avant having option 2 and Beosound having option 0, but it wouldn't work. I then tried to give the MX420 option 2 and then it worked. I have now given it option 6 and it is still working.. Confused?? I am. Still the VCR is not working 100% but I guess I need to change the ariel signal to the MX 4200 from my main installation to the Avant output instead.
    Thanks again!!!
    Søren
