Latest post 12-28-2008 8:34 AM by Chrisreunion. 1 replies.
Page 1 of 1 (2 items)
  • 12-28-2008 8:26 AM
    Re: BeoCentre 6 and HDMI cable connection
    I have recently bought a Foxsat HDR box and am trying to connect it to my BeoCentre6. Am I right in thinking that there is no HDMI connection? How do I get round this? I have the two satellite cables ready to connect. Can anyone help me on this?
    Filed under: ,
  • 12-28-2008 8:34 AM In reply to
    Hi, indeed, BC6 has no HDMI input, but it does have a DVI input, which you can use with a HDMI-DVI adaptor, it works without problem, as long as you connect the audio part via another cable between the 2 devices!
    Reunion Island is greeting you!
