hello all
since the bv7 had problems with 4.24 i had it updated to 5.02.
now when i first turn on the tv the sky box does not respond properly for the first time i use it.
if i press go once i get the banner so entering menus does nto happen
after a few mins the numbers can be used and all returns to normal
also if i have the stb setting to always on it turns the STB off when i turn the tv on and when i turn the tv off the stb stays on hence the sky hd box always gets switched off.
Anyone else have this
Beovision 7 MKIV (Blu Ray)
Beolab 9
Beolab 6000
Beo 4
Beocenter 9300
Apple TV
SKY HD
Optoma HD65 Projector
Lintronic TT455-RT-238
Beovision 3 MKII
