Latest post 12-27-2008 7:48 PM by foamywax. 5 replies.
Page 1 of 1 (6 items)
  • 12-24-2008 7:52 PM
    Beolab 4000 question
    Hi i would like to change the color of my beolab 4000 speakers from green to red.  is it possible? is it very expensive? i think someone here in the forum had posted that he had changes the metal covers... can i change the covers on my own or do i need to take it to the b&o service center?
  • 12-24-2008 7:58 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: Beolab 4000 question
    It certainly can be done! All of the parts needed will come to about £300 ish for a complete change.
    Easy to do, you just need a torx and a flat-head screwdriver, a pair of pliers and patience!!
    Lee
  • 12-25-2008 4:03 AM In reply to
    For that price, I would look for a second hand pair in the colour you want - and then you will have two pairs!
  • 12-27-2008 7:42 PM In reply to
    300 pounds? i didn't know it would be that expensive...
  • 12-27-2008 7:47 PM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Ask your dealer about the price, it could vary... The frets can be expensive (try find some on ebay)
  • 12-27-2008 7:48 PM In reply to
    thanks!
