Latest post 06-09-2007 5:07 AM by Flappo The Grate. 4 replies.
Page 1 of 1 (5 items)
  • 06-06-2007 6:41 AM
    Connecting AppleTV to Beovision3
    Hello all,
    I was lucky enough to get an AppleTV for my birthday, but am unsure if I can connect it to my Beovision 3...
    I love my TV and don't want to get a new one... Does anyone know of what leads I would need to get...
    Your help would be really great!
    Many thanks James
    Filed under:
  • 06-06-2007 10:07 AM In reply to
    Re: Connecting AppleTV to Beovision3
    After a quick search i found this thread ( http://forum.beoworld.org/forums/thread/2943.aspx ). Haven't read it though and it is for an Avant, but i suspect it also works on a BV3. It seems there is a converter for this.
  • 06-06-2007 10:16 AM In reply to
    Hello James,
    It's very easy. A little and cheap scart adaptor will do the job. See here.
    Quoi de mieux qu'un BeoLab 2 ? 2 BeoLab 2 !
  • 06-09-2007 3:45 AM In reply to
    Has anyone managed to connect an Apple TV to a BV3? i thought it was more complicated and requireed a signal converter rather than a scart adapter. I looked at the link from the previous post and that went to the apple website which didn't indicate a scart connector/adaptor was available. I've been holding off from the apple TV as I thought I would need to spend another £100 on signal converter.
    Any advice welcome.
    Thanks, Jon.
    Filed under:
  • 06-09-2007 5:07 AM In reply to
    Unfortunately the signal adapter seems the only way to connect an AppleTV to a CRT ..
    http://www.reghardware.co.uk/2007/03/29/apple_tv_to_sd_converter_price_cut/
    £90 still seems rather steep to me.
    Blame Apple for being just a bit too far ahead of the rest of the industry
    popgear is grate™
