Hi all,
Just set up a V6000 with a MX1500 (many thanks Nobby). Each seems to work ok on their own but.......
I can't get the video to work with the remote control.
a) on a Beolink 1000
b) on a Beo4
c) in either scart socket in the V6000
If I press the Sat button it transfers to the video but then none of the video commands work.
Do I need to do some AV Video sequence on the remotes?
Cheers
GUY
Train Hard - Run Fast - Hit to Kill!!!
