Hi!
My BV7-32 MK2 has begun to behave strangely with my Samsung P850 STB.
It's shuting down the STB a little now and then. There are no specific pattern when it does, it can happen at any time. But often after pressing any botton on the remote (DTV, 1, 2, 3, "RED"...) while the STB/DTV is already choosen as source on the TV.
It's connected to AV1 with a IR-transmitter.
I have tried to change the STB "power off setting" in the connection menu but it doesn't make any change. It's now set to "never"
Is the SCART sending any commands?
Any ideas?
/Ola
