1st March February 2012
Latest post 12-16-2008 3:37 AM by ChrDH. 9 replies.
12-13-2008 9:14 AM
h1npw
- Joined on 04-16-2007
- A cricket ball throw from Trent Bridge
- Posts 776
If one were to connect the 2 together would the CD5500 be remote controllable via a Beolink1000? (CD on 9000 has gone west) Cheers Nigel
Christian
- Copenhagen, Denmark
- Posts 626
Re: Beocenter 9000 & CD5500
I would say yes if it was a Beocord 5500. The Beocenter has DataLink, and I think you can control the CD5500 with A.TAPE2 if you plug it into Tape2.
Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
Addicted? Oh no.... ;)
Peter
- Joined on 02-12-2007
- Posts 9,572
Not sure! And I don't have a 9000 to test it with. However the CD5500 usually behaves like a record player with a built in RIAA. I don't think it will work via the Tape 2 socket as that will use Tape commands and the Phono socket has a RIAA built in and uses the wrong pin for Datalink. The Aux socket would be worth a try though whether the CD5500 will recognise the commands is something I cannot check. Maybe Graham knows?
Christian
- Posts 626
I know that member ChrDH has both a BGCD5500 and a BeoCenter 9000. You could PM him, and ask if he could test it for you.
ChrDH
- Denmark
- Posts 493
Hi there I would love to help, but the BEogram cd 5500 is is a setup in a different room in a closet so it is not that easy to switch around. BUT how about this: I currently got a beocord5500 connected to the BC900 as tape2. If I connect it to the a-aux connection on the BC900 and tests if that works. If it does, I see no reason why a Beogram CD 5500 should't work too. I test it this evening. Better yet, I just remembered that I got a Beogram CD 3500 sitting still. It will be very easy for me to connect it to the aaux of the beocenter 9000 and test if it works. If the remote works with a 3500 connected to the 9000, is should also work with a 5500 connnected to a 9000. I'll return tonight. br Christian
Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
ChrDH
- Denmark
- Posts 493
Well, it apears the answer is no... I tried connecting the Beogram cd 3500 to the a-aux on the Beocenter 9000 but it did not respond to any commands from the beolink, no matter if the shift radio command or the cd command was pressed in advance. So although it sounds just fint, it is not possible to remote control the beogram cd. The operating panel on the beogram cd worked just fint. On a beomaster 3500/4500 it is possible to tell the beomaster that it is a second beocord that is connected to the a.aux, so it will send beocord codes via datalink, but there is no option for a an extra cd. I quess in those days no one tought of having more than one cd-player. So if you want a cdplayer for your beocenter you should probably get a beogram cd 3500/4500/3300 where you can operate all commands up front, not only step through tracks like on the beogram cd 5500. best regards Christian
h1npw
- Posts 776
Hi Christian Many thanks for carrying out this test - it's very much appreciated. Cheers Nigel
lausvi
- Helsinki - Finland
- Posts 498
When you press AUX on BC9000 there are some options available for a moment, then they disappear. F.e if you press AUX and then 8 the BC acts as a microphone amp! I think there are options 1,2,3,4,5 and 8 available. The manual only gives the explonation of mode 8, does anyone have any experience of the other modes? Could some of them even include control of external extra-cd?
Bang & Olufsen - The art of controlling sound, picture and light
ChrDH
- Denmark
- Posts 493
I actually tried that, pressing the numbers (perhaps a bit randomly, not sure i tried all of them) but there seemed to be no difference (apart from when pressint 8 the music disappeared), but you are right, perhaps there is an extra cd mode. Another solution could be building a IR-reciver in to the datalink cable, I have heard about this once (perhaps on ebay?). In this way you are able to control a beogram cd no matter what it is connected to. The IR-reciver transfers the commands from the beolink to the beogram as if it was connected to a beomaster, and it ofcource needs 240volts to operate. Try searching a bit on ebay ect. Perhaps other members remember something about this solution? best regards Christian
Page 1 of 1 (10 items)
