Latest post 12-15-2008 10:47 AM by csmager. 8 replies.
Page 1 of 1 (9 items)
  • 12-15-2008 7:11 AM
    Beovision 4 progressive scan?
    Hi all,
     I was just wondering if the bv4 will ever be upgraded to a full HD 1080p (progressive) panel or if it will be kept at a 1080i (interlaced) panel that uses the visionclear technology to try to compensate for the interlacing.
    To me it seems strange that B&O went down the route of using a 1080i in the first place, as the overall screen's motion and picture quality will automatically be poorer than 1080p due to the difference between these 2 scanning modes.
    Surely they can just use a better 1080p panel from pansonic, and do away with the visionclear technology that tries to compensate for the interlaced scanning?
    Thanks,
     Beodude
  • 12-15-2008 7:16 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: Beovision 4 progressive scan?
    The BeoVision 4 is 1080p, both the 50" and the 65".
     Weekly top artists:
  • 12-15-2008 8:29 AM In reply to
    LCD/Plasma screens either have enough pixels to display 720p or 1080p.  They can't display 1080i formats natively, as that's just not how they work.  If you feed a tv an interlaced signal, it will have to create a progressive one on the fly using two halves of a frame that weren't processed to appear at exactly the same time - hence quick movement will look a bit rough.
  • 12-15-2008 8:55 AM In reply to
    Are you sure the Beovision 4 is progressive scan?.
    Everywhere I have seen it listed it always says 1080i - interlaced eg on beoworld.co.uk product descriptions :
     BeoVision 4 EU Specifications
    Types: AUS 8965, EEU 896, F(GB) 896, GB-EXP 896, HK 8963, ITA 8964, A-B-D-E-N-NL-SF-S-EXP 8961, CH 8962, DK 8960
    Screen and picture when combined with Beosystem 1
    Plasma display panel WXGA, HDTV ready
    Diagonal picture size 126,9 cm
    Aspect ratio 16:9 (wide-screen)
    Front mounted contrast screen Anti-reflection coated glass
    Scanning formats 480p, 1080i
    Picture display formats: Format 1: Panorama
    Format 2: Letterbox zoom
    Format 3: 16:9
    Viewing comfort Electronic curtain
    Picture format optimisation
    Tint settings stored per channel
    VisionClear Motion compensated progressive scan
    Adaptive Luminance Peaking
    Vertical peaking
    Automatic skin tone correction
    Specifications: Dimensions W x H x D
    (Dimensions W x H x D including wall bracket 1061 x 651 x 100 mm) 1061 x 651 x 130 mm
    Weight 32
     Is this info out of date or is it a just a typo?
  • 12-15-2008 9:07 AM In reply to
    It has to be garbage.  The official spec sheet says it has a 1920x1080 pixel panel, which is capable of showing 1080p.  It can't display 1080i without it first being bodged into 1080p by processing, so there's no reason I can think of that they would have prevented it showing 1080p native.
    http://www.bang-olufsen.com/UserFiles/File/ts/BeoVision4_en.pdf
  • 12-15-2008 10:05 AM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    I believe the specs. published on Beoworld's product pages are for an (older) 42" panel driven by a BS2.
  • 12-15-2008 10:12 AM In reply to
    Except for the fact that 126.9cm is 50".  I suppose they could have merged two specs together!
  • 12-15-2008 10:41 AM In reply to
    • Puncher
    • Posts 9,588
    csmager:
    The external dimensions given are 1061 x 651 which would give an outside diagonal dimension of ~49".
  • 12-15-2008 10:47 AM In reply to
    Puncher:
    So it does.  I get an outside diagonal of 124.5cm, which is smaller than the quoted picture size.  I think it's fairly safe to say this spec sheet isn't very accurate!
