i got those code from Lintronic and i wonder if you can make it whit this XML files to control Beo 5.
Does anyone have any ide if i can do that.
Regards Claudiú
| LinTronic Command | Function |
| 713001014000000000000 | 0 |
| 713001001000000000000 | 1 |
| 713001002000000000000 | 2 |
| 713001006000000000000 | 3 |
| 713001004000000000000 | 4 |
| 713001005000000000000 | 5 |
| 713001007000000000000 | 6 |
| 713001008000000000000 | 7 |
| 713001010000000000000 | 8 |
| 713001011000000000000 | 9 |
| 713001026000000000000 | AUDIO |
| 713001019000000000000 | CH.LIST |
| 713001022000000000000 | CHANNEL.DOWN |
| 713001021000000000000 | CHANNEL.UP |
| 713001030000000000000 | DECODE |
| 713001018000000000000 | ENTER |
| 713001017000000000000 | EXIT |
| 713001024000000000000 | GUIDE |
| 713001031000000000000 | HDD.DEL_SKIP |
| 713001009000000000000 | HDD.LIST |
| 713001032000000000000 | HDD.MENU |
| 713001028000000000000 | HDD.RECORD |
| 713001025000000000000 | INFO |
| 713001016000000000000 | MENU |
| 713001003000000000000 | MUTE |
| 713001000000000000000 | POWER |
| 713001013000000000000 | PREVIOUS |
| 713001029000000000000 | SLEEP |
| 713001012000000000000 | TV_RADIO |
| 713001015000000000000 | TV_SAT |
| 713001020000000000000 | VOLUME.DOWN |
| 713001023000000000000 | VOLUME.UP |
