1st March February 2012
Latest post 12-15-2008 7:20 AM by Alex. 11 replies.
12-13-2008 7:03 PM
Thingen
- Joined on 12-13-2008
- Posts 3
Hi.. I have a pair of beolab 8000 speakers and I am thinking of buying af beosound 4 and a beolab 2. Is it possible to connect my speakers and the sub to beosound 4 i a stereo setup thanks in advance /Thingen
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Re: beosound 4 and beolab 2
Hi there. Yes, you connect the Beolab 2 to your Beosound 4, then both your 8000s to the Beolab 2. This way, the Beolab 2 handles the lower frequencies and leaves the 8000s to handle the rest. For some strange reason, 8000s can't be daisy-chained Andy T.
Thingen
- Posts 3
Hi Andy. thanks for your reply. sorry, but could be explain daisy-chained to me - this is a bit new to me :) thanks /Thingen
hebo
- Joined on 04-16-2007
- Sweden
- Posts 305
hi Tingen, daisy-chain is when you connect your speakers in a chain, ex. you only need one powerlinkcable from your BS4 to your first speaker and then you connect another powerlinkcable form the first speaker to the second one. Both left and right signal is in the cable. This way could sometimes make it much easier to plan for the wiring.
nmartin771
- Joined on 02-18-2008
- Novi Sad, Serbia
- Posts 3,103
Strange? Are you sure Andy that you can't daisy-chained BL8000 ? As I know you can daisy-chained every BL speakers ....
when your Black Label begin to taste like juice just take shot or two of Absinthe and
after that quench with some vodka, if you still feel juice like take beer
with grappa !
Alex
- Bath & Cardiff, UK
- Posts 2,990
You can't do it with BeoLab 8000s because they don't have dual PowerLink sockets. There is a T-Adapter available from B&O which allows you to daisy chain them though.
Weekly top artists:
KingOfSnake
- Joined on 02-07-2008
- Posts 359
The standard T-Adaptor available from B&O is a poor solution, unless you want to see unsightly wiring at the back of the 8000's. Better still buy, for example a 1m powerlink cable, a T-Adaptor and a female to female adaptor in order to make off the daisy chain connection somewhere less conspicuous.
Christian
- Copenhagen, Denmark
- Posts 626
I agree with KingOfSnake. My parents did the same, and this way you can use the thick rubber cablecovers that were designed to go with the 8000s. Another speaker missing the second PowerLink socket is BeoLab 4. I my view BeoPort and BL4 are the perfect PC pack, and therefore I think it is a bit annoying that the BeoPort only have one PowerLink out so you have to buy a T-splitter if you want to connect BL4s to it.
Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
Addicted? Oh no.... ;)
Alex
- Posts 2,990
It's worth noting that you don't actually need to daisy-chain speakers connected to a BeoLab 2, as it has two PowerLink outputs.
Weekly top artists:
Steve at Sounds Heavenly
- Joined on 05-18-2007
- In the cable workshop, Melton Mowbray, UK
- Posts 356
Good point! However, for anyone reading doesn't have a Beolab 2, but wants to add numerous Beolab 3 or Beolab 8000 speakers together (both of these have only one Powerlink socket fitted), you can use a "Y" adapter to give an extra socket. Yes, the B&O version is too short for tidiness in many situations, but these can be found in longer lengths from other cable companies to allow the wiring to be hidden into cable covers/stands. Best regards, Steve.
Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
Alex
- Posts 2,990
Usually however, installers tend to wire a PowerLink junction themselves, which is more discrete and much more reliable when done properly.
Weekly top artists:
Page 1 of 1 (12 items)
