Hi.
I have bought a Beo5, and I`m really happy for it. And I was also lucky and got the Beo Configurations tool program. But two things I can`t do, as I can with my Beo4 is to adjust Picture and Speakers. If I have my Beo4 and push LIST, and then PICTURE, and then number 2, it will change to widescreen on my Beovision 3. But sometimes when you do that, you can miss some text in the buttom of the screen, and then you can use the UP and DOWN keys to move the picture. It seems like impossible on the Beo5.. Also when I want to hear sound in 4 speakers through the Surround modul, I can on the Beo4 push LIST, and then SPEAKER, and then number 4,to listen in all 4 speakers. And then I can use the UP and DOWN keys to move the sound from the rear speakers to the front speakers and back again. But when I use the Beo5, and push SPEAKER and then 4, and then try to use the UP and DOWN keys it just change radiochannel or track if I listen to a cd. Does somebody in here know, if it`s possible for the Beo5 to do the same as the Beo4, and if so, do you know the code for it in the Beo Configurations tool program. Hope somebody can help.
I can only say I`m very happy for my beo5, and really like the way you can make small macros. Everytime I turn on the cd or radio, 4 speakers will turn on, and when I push dvd, all 5 speakers will come on. So very pleased.
All the Best
Carsten M. Soerensen
Denmark
