Hallo.
I find myself with too many AV sources and possibly not enough input ports on my Beovision MX8000. I'd appreciate any advice on how to connect the maximum number of these to the TV with minimal fuss.
Current setup:
Beovision MX8000
- HDR1 (connected to V.Tape on MX) :
a) STB (connected to AUX on HDR1)
b) DVD1 conenected to DVD on Expander
Not connected yet:
Can the DECODER/STB port on the AV2 Expander be used as an input for Beocord V8000?
Can the Comcoder port on the MX8000 be used ( possible wiht IR?) for Beocord V8000?
Hope this makes some sense.
Thanks to all.
Gintas
