Latest post 12-08-2008 12:35 PM by Friedmett. 8 replies.
Page 1 of 1 (9 items)
  • 12-05-2008 8:55 AM
    • lucas
    • Not Ranked
    • Joined on 12-02-2008
    • Posts 2
    beovox x35
    hello
    Can somebody tell me if it is good idea to buy Beovox x35 speakers. Now I have beomaster 1900 and I need some spekers.
    I can't find any useful informations about them.
    The problem: it's verydifficult to find some old B&O speakers in my country. (POLAND)
    I can also buy Beovox MC 35.
    Should I buy one of them or wait and try to find something else.
  • 12-05-2008 9:47 AM In reply to
    Re: beovox x35
    i think i would wait...
    s45 (the early rubber surround) is a great speaker for the 1900 and not very expensive!
    • B&o bottle opener
  • 12-05-2008 10:09 AM In reply to
    Re: beovox x35
    Wouldn't go for either of these! Of course you don't have to use B&O speakers either. S45-2s are certainly the ones to look for if you want B&O though.
  • 12-05-2008 10:16 AM In reply to
    • Xseries
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Hampshire
    • Posts 433
    Re: beovox x35
    Hello,
    If you can wait and find something else I would as I think these are not up to the same standard as some of the other B&O passive speakers.
    It really depends on the local market.  If they are not too dear then you might be able to sell them and replace them with something better at a later date.
    How much are the X35 and how much are the MC35?
    Brian
  • 12-05-2008 11:38 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: beovox x35
    Peter :
    I agree completely, the X35's are really not very good at all and I have consigned a pair of MC35's to our shop floor at work.
    S45-2's are infinately better.
    Chris.
  • 12-05-2008 5:16 PM In reply to
    • lucas
    • Not Ranked
    • Posts 2
    Re: beovox x35
    Xseries:
    Brian
    Both almost same price: something about 45-50 euro. I bought my beomaster 1900 for 55 euro so I think this speakres are quite expensive.
  • 12-06-2008 3:54 PM In reply to
    • Xseries
    • Hampshire
    • Posts 433
    Re: beovox x35
    If you need something to enable you to use the BM1900 then I would choose the MC35s over the X35  - but if you can wait for something else I would not spend any money now.
    Brian
  • 12-06-2008 5:56 PM In reply to
    • Craig
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: beovox x35
    Remember that you can of course use some non B&O speakers until you find some.
    CraigSmile
  • 12-08-2008 12:35 PM In reply to
    Re: beovox x35
    I had the Beovox X-35 as Beoworld said they were the original ones for the '80s Beosystem 2000 which I had.
    I got a very nice pair but the sound was horrible. My parent's still going Beovox S45 from 1979 sounds way better. I ended up with some other non B&O speakers but keeping the X-35's to keep the system original.
    I sold the 2000 system and the seller did not want the better/bigger non B&O speakers but the X-35s with the system. Both were avaible for sale.
    Now its Beovox S80.2,S120 in pairs and M150 single pair type which are the bigger brothers. The S45 still sounds in that range. Very pleasent for the ears.
