Hello AGAIN, to everyone!
I posted previously re an RX-2 turntable that worked for 'a while", then...stopped working for "a while'.
i was advised that it could be oxide coating on the "press-for on" switch.
However, when repeatedly pressing the start up switch on the front right, after 3-4 pushes, i hear a "click" which will then allow me to manually spin the turntable & have the tonearm cycle. Yes...i DO support the arm so it doesn't get damaged.
If it really WERE the switch/oxide coating, why would i get the click that allowed it to cycle?
Note that the turntable did not spin on its own after the "click".
Thus...i still have a problem (intermittent).
Any ideas now?
Thank you all...and Chris for your help before.
Jerry
