1st March February 2012
Latest post 02-03-2009 2:51 PM by Puncher. 11 replies.
02-03-2009 2:13 AM
Xseries
- Joined on 04-16-2007
- Hampshire
- Posts 433
...if everyhting is half (can't really call it Beolab1 though) - will it go down to half the frequency level of the old one????
Brian
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
Roger,
If your sources are right, then Beo is making something completely wrong... Again!
I mean, the BL2 isn't that good, and making something smaller sound wise and less performing?
Oh dear...
To what use? Connected to ones computer?
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
burantek
- Joined on 05-04-2007
- SE USA
- Posts 6,214
bayerische:
Roger,
Oh dear...
i don't know... but i like the idea! i think that the bl2 is a bit pricey and may not suit my avant room well. i think that a lesser sub (hopefully w/ better music response) would put me in line to buy one!
bayerische
- Helsinki, Finland
- Posts 3,593
Jeff, the faster and punchier the sub, the more expensive it is to make.
Beo is not going to be able to build a better sub for half price...
For example the best sub I've ever heard is the ELAC 2080. It costs 3378 euros. It has ICE power and and digital crossovers.
PDF file: You can trust it! http://scanteknik.fi/userfiles/documents/elac/Subwoofer/sub2080D.pdf
It seems to be very difficult to make a good subwoofer. Subwoofers with a lot of sound and boomy bass is easy, they simply don't go deep enough.
Beo should make something on par with the Bass in the Beolab 5's. Fast, deep and responsive.
Small drivers won't cut it, since they can't go deep enough at a reasonable sound pressure.
-Andreas
bayerische
- Helsinki, Finland
- Posts 3,593
I've heard that too, the ELAC I linked to is also in a push-pull configuration.
A "musical" sub is indeed expensive and difficult to make.
-Andreas
Page 1 of 1 (12 items)
