Latest post 12-13-2008 4:52 PM by Friedmett. 1 replies.
Page 1 of 1 (2 items)
  • 12-13-2008 1:27 PM
    • Mico
    • Top 500 Contributor
    • Joined on 05-06-2007
    • Finland
    • Posts 136
    Smoked Beomaster 6500
    I got a practical example why you really should disconnected the BM from mains before doing cabling issues in a MCL setup. The result was some bangs, maybe three and a dead BM 6500. The main fuse was blown but that did not resolve tho whole issue. When I connect the BM to mains the BASS, TAPE 2 and TIMER OFF are lighted and a small spark is seen from a relay unit under plastic cover. These are only signs of life in the BM in addition to the normal humming from the transformer.
    Is there anything I can do myself, should I give up and take the unit to repair shop or or is the unit irreperable?
  • 12-13-2008 4:52 PM In reply to
    Re: Smoked Beomaster 6500
    The unit is not irreperable but to many B&O dealer ships they are because of age.
    A few might give it a look but they most likely do not have the knowledge to fix it.
    Get in contact with Dillen here. He can help you out all the way.
