I know they have to be 4 amp (20mm x 5mm) fuses but which ones are the best for this system? Is it the 'slow blow', the 'fast blow' or the 'anti surge'? Does it even matter which ones I put in? I only had some 2 amps so put them in but they blow at volumn setting 8!!!!
Many thanks.......Sam
