Latest post 11-18-2008 4:55 AM by avus17. 2 replies.
Page 1 of 1 (3 items)
  • 11-18-2008 4:51 AM
    Connecting VGA PC output to BV7 DVI-I input
    I have bought a VGA to DVI-I cable an connected PC to BV7 32'',  I have done everything as described in userguide. But I can not get a PC picture on TV.
    Are there different DVI-I cables where perhaps I should be careful? PC output is set OK, so picture should be seen on PC (laptop) and TV.
  • 11-18-2008 4:53 AM In reply to
    Re: Connecting VGA PC output to BV7 DVI-I input
    Just being paranoid, but have you told your laptop to output via VGA out? there is usually a botton that looks like a monitor that allows you to do so.
  • 11-18-2008 4:55 AM In reply to
    Yes I have done this, so PC sends signal to TV, but still no picture. Could be a deffect of HD module a cause for this?
    HD module was built in later by B&O service department.
