darioazul: You are correct--Beocom 4 isa stand alone unit. You would need either Beocom 6000 (I don't recommend this unit. In the US, it had many issues.) or Beocom1 &/or Beocom 2 combo plus the base station. The base stations lets you control up to 8 handsets, either all Beocom 1s or 2s or a combo of the two.
The Beocom 2 is not as impractical as it seems. Once you get use to holding the phone lower than normal the design purpose makes sense. The sound quality is very good. When not in use, it looks like a modern sculpture.
Enjoy,
Dario
Interesting. What kind of "issues"...? Could you expand please?
Are these issues confined to the US market or do they apply to UK models too?
Any UK users have any problems with the BC6000?
Dario, noted on the beocom 2, and I'm sure after a while I'd get used to the function. However, I still don't like the form. For me, it's over- stylised. Almost design for the sake of being different. Does nothing for me I'm afraid. And nor does the price.
Thanks for your input
Dan
