Hello All
I am trying to orgainse my mp3s on my beomedia into track order and i knwo you need to change the title info in the advanced tab of the track info.
does anyone know of a good free peice of software that i can edit tracks quicker rather than one at a time with over 5000 it will take me some time.
Beovision 7 MKIV (Blu Ray)Beolab 9Beolab 6000Beo 4Beocenter 9300Apple TVSKY HDOptoma HD65 ProjectorLintronic TT455-RT-238Beovision 3 MKII
I use Tag&Rename
very good very pro.
"Tag & Rename" is a really good mp3 tag editor: very quick for bulk tagging, and easy to use
I'm quite sure it will work normally during the free trial month... do a little try, nothing to lose!
Santiago
If you're using a PC, I've used Ultratagger in the past and it worked fine (and the first month is license free).
Go with ID3 TagIT - it is freeware.
Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
or just download
Apple iTunes.
It's free for Mac and PC and you can edit multiple track easy (e.g. mark complete albums, name their title, artists etc.)
Well, I tried at least 10 different programs.
ID3Tag let you use shortcuts/keys to get file name and put in the the tags etc.
This makes it very useful to have tag and file naming the same for all your music.
Even today I use it before reading the files on the NAS with i-tunes.
