you post a lot of these alone in your darkened room listening to Grado headphones, don't you. I can tell these things.
loving the pop up quick reply box!!
(smiley pop up box is a bit slow, though)
PD
"The difference betwixt erotic & kinky is that betwixt using a feather & using a chicken..."
