I have a brilliant beosystem 3500 which when first connected a few months back, after buying it on ebay, had the speakers about 6 inches apart (sadly)...
Now that i am moved into a new house it has a new home - it looks great in it's new position (hanging) and the speakers are where they should be
that is when i noticed that the CD was outputting left channel only... it may have been before but it was not used much (so it could have been a problem from the beginning)
the ipod on aux input and the tuner work just fine, both channels. and the ipod plugged into the CD port also provides both channels
all of which narrows it down to the CD, and hopefully the cable -
is there anything here, without any testing equipment, that i can do? i could see opening the back of the CD player and seeing if the cable appears terminated correctly but beyond that i am asking for suggestions - thanks for any ideas...!
