Latest post 11-15-2008 3:20 AM by Peter. 3 replies.
Page 1 of 1 (4 items)
  • 11-09-2008 6:53 PM
    • barryf
    • Not Ranked
    • Joined on 11-09-2008
    • Posts 2
    b&o 5000 turns off after 5-10 seconds
    hi,i have purchased a second hand 5000 set up that switches off after about 5-10 seconds,can any one help please
  • 11-10-2008 2:53 AM In reply to
    • Ben
    • Top 500 Contributor
    • Joined on 12-28-2007
    • Taunton, UK
    • Posts 131
    • Silver Member
    Re: b&o 5000 turns off after 5-10 seconds
    This is a really common problem (assuming its the later, 1980's Beomaster 5000 you're talking about)
    Do a search for 'Beomaster 5000 idle current'
    Cheers,
    Ben
  • 11-15-2008 2:20 AM In reply to
    • barryf
    • Not Ranked
    • Posts 2
    hi,sorry for the delay ,but thank you will get it checked....barry
  • 11-15-2008 3:20 AM In reply to
    Agree - will need some new capacitors and variable resistors in all probability. "All" you need to do is find someone to do it for you!
