Latest post 11-04-2008 1:34 PM by MoglesMac. 4 replies.
Page 1 of 1 (5 items)
  • 10-31-2008 12:35 PM
    MCL2AV + New Bang & Olufsen Speakers
    Greetings all,
    I have right now a link-room with a pair of Beovox 3000 but i plan to hunt down a pair of Beolab 4500 and for that i have bought two MCL2AV, one with Powerlinks-connections only (type 2034) and one with additional Speakerlink-connections (type 2020). I know both will run the Beolab 4500 BUT should both be able to run any of the new Bang-speakers? (thinking mostly of Beolab 3, Beolab 4 or Beolab 8000).
    Thanx in advance.
    Jesper
  • 10-31-2008 12:45 PM In reply to
    Re: MCL2AV + New Bang & Olufsen Speakers
    Should be no problem at all. The only one which could possibly have an issue would be the BL3 as these can be slightly sensitive to hum. However using the correct Powerlink cables should prevent you having problems.
  • 10-31-2008 5:20 PM In reply to
    Ahh thanx for the quick response. I still opt for the Beolab 4500 but I also like the look of Beolab 4 :) a bit more futuristic hehe.
    Thanx
    Jesper
  • 10-31-2008 6:46 PM In reply to
    The 4500 sound a lot better!
  • 11-04-2008 1:34 PM In reply to
    Yea the Beolab 4500 is my "dream-pair" for bedroom but how would a set of Beolab 6000 hold up? comparisonwise?
     The 4500 is very "sparse" to get hold of but im in no hurry tho :D
    Jesper
    Sweden
